TwinTurbo.NET: Nissan 300ZX forum - ^^^I just resealed my valve covers not too long ago and I
YlwPrlZTT
on April 14, 2016 at 2:15 AM
The intake gaskets do require a small amount of RTV, where
posted by jzack
on April 13, 2016 at 09:42 AM
used RTV for both covers like jzack said. Check in the back around where the VTC solenoids are and see if anything is leaking there.
Valve cover dilemma?
KeepinitClassy
17:58:55 04/12/16
Can you describe the procedure followed for the valve cover
jzack
20:02:09 04/12/16
Re: Can you describe the procedure followed for the valve cover
KeepinitClassy
20:57:24 04/12/16
Re: Re: Can you describe the procedure followed for the valve cover
Cjw3
22:15:28 04/12/16
Much more likely that it's an injector or coil pack issue
01:13:10 04/13/16
jzack
09:42:43 04/13/16
^^^I just resealed my valve covers not too long ago and I -
YlwPrlZTT
02:15:57 04/14/16
Re: The intake gaskets do require a small amount of RTV, where
KeepinitClassy
04:47:42 04/14/16
Back of the motor at tranny junction could very likely be
jzack
12:35:11 04/14/16
Sorry forgot to add, normally a crank rear seal leak doesn't
jzack
13:42:40 04/14/16
If you don't see oil dripping
FrozTTy
08:10:23 04/13/16
Re: If you don't see oil dripping
KeepinitClassy
04:49:53 04/14/16
Check the brake master cylinder, too
ChristopherTheOne
23:25:58 04/13/16
Re: Check the brake master cylinder, too
KeepinitClassy
04:52:20 04/14/16
Re: Valve cover dilemma?
wb3ztt
14:25:35 04/14/16
